How to change signature on profile?
I know it is a quite dumb question, but I am not able to find where can I change the signature that appears at the bottom of every post you make.
On mine appears "www.evovelo.com" probably I put it myself, but long ago, and do not remember were I did it.
And I will like to modify it.
Thank you for your help.
You can go to https://forum.onshape.com/profile/signature and change it there.
Alternatively, you can use the gear icon in the top right corner and choose settings, then choose signature from the list at the right.
