any way to create an object shaped like this with surfaces in onshape?
mj_powers
Member Posts: 18 PRO
trying to figure out how to create a shape like this in onshape.
just the basic shape, not all the twig detals.
was trying to wrap a helix around a sphere, but that doesn't work.
any advise would be greatly appreciated.
The most direct way is to use this featurescript. One of the included examples is actually a spherical helix. With a little parameter tweaking you could make it look like the one from the picture (minus all the twigs). Then copy it via a circular pattern.
https://cad.onshape.com/documents/578ff8b3e4b0e65410fcfda3/w/d33395f174e5b38f4abd6097/e/46b903b8bff0b36927baa2a6
You can also do it without featurescript, but it would require splitting a helical swept ribbon surface with a spherical surface.0 -
okay thanks! i will give it a try
