Chamfer direction
When chamfering few edges together using "Two distances" or "Distance and angle", how can I change direction of a single edge without affecting the other?
1
andrew_troup Member, Mentor Posts: 1,585 ✭✭✭✭✭
I don't think that is currently possible, at this stage of Onshape's development.
If the layout of the solid(s) is such that the chamfers do not respect your intentions, you will have to split the set of edges between two features.
Given that (unlike other MCAD solid modellers) Onshape chamfers can be created on multiple bodies with one feature, I see this as an important future addition to the chamfer tool.5
I realize this is extremely old, but I ran into the same issue. There is now a section of the chamfer tool called "direction overrides" which allows you to individually select edges to flip the direction on. Just click on that box and select the edges to reverse.
