Categories- What am I doing wrong?
colemancoleman OS Professional Posts: 244 ✭✭✭
I created a new category and set it to active.  When I go to the properties of the part, and select the new category from the picklist I see my new properties BUT they are ghosted out and I cannot type in them.
The VENDOR UNIT PRICE is a field I created but as you can see, it is grayed out and I cannot type in the field.
Thanks for the help
  • Ram_VangapalliRam_Vangapalli Member, Onshape Employees Posts: 1 image
    There is an attribute for the property “Edit value in workspace” that should be checked to enable it for a workspace. It is off (unchecked) by default.
    @Ram_Vangapalli. you got it.  Thank you
