Units on Hole Callouts
fintan_healy229fintan_healy229 Member Posts: 1 EDU
When I went back into an old drawing this morning the units on the hole callout have changed to 'inch's' whereas everything else on the drawing ( and indeed the respective 3D model ) is in 'mm'. So my questions are:
a) how have I done this?
b) how do I get the hole callout to be in 'mm' again?
Thanks in advance,
Fintan
  • shaun_singhshaun_singh OS Professional Posts: 22 PRO
    They fixed this bug late last night - I didn't have to change anything on my drawings so they should revert back without doing anything
  • jakeramsleyjakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 664
    This is something we noticed shortly after our latest release and have deployed a fix for.  This should no longer happen and if you are noticing any oddities with drawings and units, please submit a support ticket.
    Jake Ramsley
