Does Onshape API have CORS enabled?
Jangho_JungJangho_Jung Member Posts: 1
I'm trying to make frontend API calls from the browser to the Onshape API, but I'm running into some issues with CORS. Does anyone know if Onshape API has CORS enabled? Or has anyone successfully worked with the API without serverside programming ( ex. no python or nodejs ) ?
  • awkawk Member, Onshape Employees, Developers Posts: 78 image
    The Onshape API does not support CORS. You'll need to use some type of service that is not entirely based within a browser. A lambda service or similar would work fine, you do not necessarily have to setup your own infrastructure.
    Director of API, Appstore, and App Partner Technical Support
