Blended Learning, Playlist for 3D printing
Hello fellow teachers, wondering was anyone created or played with a blended learning technique using 3D printing classes.
Blended learning playlists is a list of projects where students have freedom in creativity but an outline what what is expected to turn in. Most teachers that have these in their classes have a date timeline. By October 15th you must have completed 5 of these projects.
Trying to work on developing on for my 3-D printing class, but lacking creativity.
Any help would greatly be appreciated.
This sounds very interesting approach. Around here there are schools with 3D printers, but they seem underutilized. It would be nice to exchange some ideas of how to facilitate that. Sometimes creativity is also suppressed by the lack of knowledge of that is/is not possible with the tools avaliable.
We start with a few required projects that build skills. A cube puzzle, a cube with a hole, linear/circular patterns, revolve, make a part from a drawing. We then move to duplicating a Lego of the student's choice. They use calipers to take measurements then design the part in CAD. This allows them to differentiate the project based on their confidence. Next, we have a partnership with an Art class, designing household products. CAD students choose their next project from the designs made by their peers in the Art class. After that, the CAD students can propose their own projects. Throughout the course I offer a few design challenges for no points (Expo marker, pencil, horseshoe, fidget spinner).
@emily_larae_smith PTC Academic has recently designed an exercise especially for users new to CAD and/or Onshape— the "Eyeglasses Editing Exercise", that might fit your needs. This exercise shows new CAD users how to edit and customize an eyeglasses frame using a public Onshape Document, and prompts them to export the results for 3D printing. You can try it here.
We've also worked with Tufts University Center for Engineering Education and Outreach (CEEO) to develop additional Onshape exercises. Here's a link to a page of Onshape Challenges if you're looking for more open ended exercises: https://sites.google.com/view/onshape-challenges/home.
fascinating exercises! I would like to share with some students. I am not seeing how to get the documents at the 'onshape-challenges' page? Are they public and where do we access?
Students look at the Bic Pen, we discuss what makes an iconic product and look at pens that have copied the design. Students then record the dimensions of the pen barrel, cap, end cap and most importantly the Ink reservoir. Students then move to onshape to make a copy of the reservoir. A drawing is created of the reservoir with say 8 front views on an A4 sheet. This allows the students to then create their own ideas for a barrel shape. They can consider having a cap. Once their first few drawings are done, we look at ergonomics and comfort of shapes. Play doh, plasticine or polymorph can be used to assist students look at shapes and easily change their ideas. Card models can also be made using a layer/ slice modelling technique. This helps students visualise sizes in 3D.
Then its back to the sketches and finalisation of shape, before coming back to Onshape to make the barrel.
When modelling there are different ways of approaching it which is a good way of demonstrating onshape features, start with a solid and hollow, revolve a profile, loft shapes etc. It is also a good time to revisit the original barrel and reservoir. Look at how the reservoir is held in place, the hole in the barrel and cap (why are they there?). It gets students to really look at the minute detail of a product. You could even introduce tolerances! are all the barrels exactly the same size? are the reservoir ends all the same diameters - can they be interchanged? why are they manufactured this way?
When they have a final design - It's time to look at how it will be printed. Which orientation will it be printed in? Does it need splitting in half? how will they be joined? quality of print? does it need support or raft.
If you decide to print them. While the barrels are being printed, students present their work and then look at other refill reservoirs that are available. and create designs for them, If I do this we look at Zaha Hadid ( the queen of curves) and the Buildings the company have created all over the world as inspiration for their 'iconic' design.
When the barrels are printed the moment of truth is when they put the reservoir into it... does it fit? Is it the right length? does it fall out? and importantly is it comfortable to use?
Hope this is of use!
See private message @stephen_wilson554
A good way to share all your resources might be a folder in Onshape. You could import the powerpoints into the relevant Onshape documents and then move the documents into a folder that you could share with interested individuals.
Another option would be to turn link sharing on for each of the individual documents and post those links. These are just two ways within Onshape. Other educators might have a better idea how to share these resources!
Hope this helps to show the blended learning that my OCR Engineering Design students take. Don't forget inbetween all of these projects is the theory and many other elements of the course specification/ syllabus are covered.
