Cockeyed parts - Methods for viewing imported components not positioned or aligned
bruce_williams
Member, Developers Posts: 842 PRO
Here is an outline of tips & tricks for viewing parts in true part alignment. It is a common challenge for us so we put together the outline and videos which I will post next. Not the only way for sure and will be glad to hear feedback. Hope it helps! - Bruce
PDF outline - https://cad.onshape.com/documents/525e74d35861a288dbf3b1b7/w/1de201cd7d15580088e21c88/e/3b98872cca8048e028b7d968
www.accuratepattern.com
https://www.loom.com/share/197995fccd2b4dd19bee076c7e8258d4
https://www.loom.com/share/17163bfd21fa4f9ba11c6ae3b5762b63
https://www.loom.com/share/f0503bb89f654d95acfdb491ac498c81
End transform result:
Nice and aligned for editing:
Nice videos by the way! I learned some good tips and tricks for using named views and mate connectors.
Thanks for the comments and example. Yes, moving with Translation by Mate connectors is often a good option. We have decided to keep imported positon so we always have World & Part coordinates. It creates challenges yet we need to stay consistent and there are advantages.
Website: ovyl.io
And I appreciate all the info & work you have contributed to forums and FS code & icons. Being connected to Onshape and the community is a real blessing. I learned about Loom here (from you I think) and it is a nice tool for videos.
Website: ovyl.io
I added an example 'Cockeyed' part with MCs & Named views to the document.
