Evaluate pixels in an image import?
EvanReeseEvanReese Member, Mentor Posts: 2,697 PRO
When using the image reference parameter, is it possible to get color data about the image at a point? If so, I could use this data to drive all kinds of cool stuff, like hole sizes, and could make an "Image Pattern" feature.
    No, this is not possible today. It's not high on our priority list, since you generally don't want to be working with large amounts of non-CAD data in FS during part regeneration.
    The alternative I would recommend is doing some preprocessing of the image to make a CSV file, and uploading that.
  • EvanReeseEvanReese Member, Mentor Posts: 2,697 PRO
    Thanks @kevin_o_toole_1 I figured as much, but wanted to ask. This isn't an urgent need; more of a curiosity. I still know nearly nothing about other languages, but a quick search seems to show that Python would be good for making the CSV. Maybe someday.
