Select default transform type
crudo
Member Posts: 2 ✭
Hi, is there an option to select different default transform type than Translate by line?
I rarely use this type.
I would prefer to have Translate by XYZ as default option so I do not have to change it almost every time.
Optionsbruce_williams Member, Developers Posts: 842 PROHi @crudo
welcome to the forum! Improvement requests are the method Onshape uses to prioritize changes. You could enter a new one or this one is similar to what you are asking. https://forum.onshape.com/discussion/5316/remember-last-transform-method-or-any-feature-dialogs
www.accuratepattern.com5
