Different K factors in the same sheetmetal part?
William_SchlundWilliam_Schlund Member, Channel partner Posts: 9 ✭✭
Can you have different K factors assigned to different bends in the same part?
Sometimes a part will be formed or bent on two or more different machines that require a different K factor depending on the machine used.
Or
Two different edge set ups with two different radii that require different K factors.
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 944 ✭✭✭✭✭
    I don't believe that is possible currently in Onshape. @lana is this correct?
    It would be nice to have because I run into this scenario sometimes.
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • lanalana Onshape Employees Posts: 746 image
    No, not available yet. Please vote for an IR
