Offset Adjacent Faces
Cache_River_MillCache_River_Mill Member Posts: 225 PRO
Link:
https://cad.onshape.com/documents/725911b3d26eaad0ab951314/w/1915daf3a2ddbe886b6609db/e/60183b84fdc53387a76d037a
Created by:
Michael Pascoe, Cache River Mill.
Description:
This custom feature offsets the faces
adjacent to the face you select.
Prerequisites:
A solid body with more than one face.
Notes:
  1. Select a face.
  2. Choose the offset thickness.
Application:
This feature is most useful when you need to edgeband an entire wall of various panels.
    Evan_ReeseEvan_Reese Member Posts: 2,064 PRO
    hey, cool idea! I can see this being super handy for you after seeing the gnarly cabinet setup you posted. To me, it might make more sense being called "Move adjacent faces" since it's really more similar to the move face command, right? I'll add it to my toolbar.
    Evan Reese / Principal and Industrial Designer with Ovyl
    Website: ovyl.io
    oh, and you know how much I appreciate that it already has an icon :smiley:
    Website: ovyl.io
    edited September 2020
    Thanks! @Evan_Reese
    You're right, it is derived from the move command. I intentionally used the word "offset" so that it would be easy to find. I would not have thought to search for a feature called "move" even though it is technically moving the adjacent faces.
    Well in that case you're experiencing one of the luxuries of writing your own features; you get to do whatever you want! live it up. Seems like a good enough reason to me. It would be nice if we could add tags to features so you could search a similar work, like how searching "round" asks "did you mean fillet?"
    Website: ovyl.io
    Two thoughts on the UI:
    1. it looks like you'd essentially like to have no limit on the number of faces selected since you set it to 100. If you just delete this, it won't have a limit
    , "MaxNumberOfPicks" : 100
    2. if you prefer to have a different default value (this feature seems like it's for clearances so the default is probably too big) you can replace this
          annotation { "Name" : "Offset" }
          isLength(definition.Offset, LENGTH_BOUNDS);
    with this
          isLength(definition.Offset, {(inch) : [0,YOUR_DEFAULT,1e5)} as LengthBoundSpec);
    Website: ovyl.io
    Thanks for the tip, much appreciated. I am getting an error when I replace the isLength. I'm very new to featurescript.
    Try changing "defaultInput" to whatever number you want to be the default value. Looks like you also need to replace ")" with "]" which I also missed in my example  :#
          isLength(definition.Offset, {(inch) : [0,2,1e5]} as LengthBoundSpec);
    I'm still fairly new to it as well, so I can still remember all the silly stuff I got hung up on starting out (and still do as you can see).
    Website: ovyl.io
    That did it. Very nice  B)
    I'm trying to put a manipulator on this. It would be nice if it were on one of the moved faces but I will take anywhere for now.
    Could you give me another pointer? My code is not quite there, probably way off actually.
    Here is the feature on branch B1
    https://cad.onshape.com/documents/725911b3d26eaad0ab951314/w/c77dd9c784148297a7d5707a/e/6dee0c37cda944e0b01e5cb0
    emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 859 ✭✭✭✭✭
    @Cache_River_Mill You can use the Thicken feature to do something like that with a lot of other options
    Un saludo,
    True, that would be another good method. Personally, I like how "move face" calculates extensions, thicken seems to have trouble sometimes depending on the application. Thicken would be great for adding edge band material to a part. Perhaps I could incorporate both as an option; remove the material, then add it back as a new part.
    The thicken solution is good for some things, but isn't super robust to change imo. The selection needs to be redone if a new face is added, Also, the face IDs will change, but with the Move Face they remain, which would update anything downstream that's related. I also don't think the thicken method would work for just changing the edge faces, but not the caps of the hexagonal thing since it would cut in at a non-perpendicular angle. All that to say that @c@Cache_River_Mill will probably still get a lot of value out of this custom feature if it's something they do often.
    re: manipulator. I've never used one, but it has something to do with the Manipulator Change Functions and Editing Logic stuff at the bottom of the page. Let us know how it goes.
    Website: ovyl.io
    Also, since you mentioned that you might need to "edge band an entire wall", you could probably make an option that selects all faces that are co-planar with the first selection to save time picking the rest.
    Website: ovyl.io
