Offset Adjacent Faces
Cache_River_Mill
Member Posts: 225 PRO
Link:
Created by:
Michael Pascoe, Cache River Mill.
Description:
This custom feature offsets the faces
adjacent to the face you select.
Prerequisites:
A solid body with more than one face.
Notes:
Select a face.
Choose the offset thickness.
Application:
This feature is most useful when you need to edgeband an entire wall of various panels.
1
Website: ovyl.io
Website: ovyl.io
You're right, it is derived from the move command. I intentionally used the word "offset" so that it would be easy to find. I would not have thought to search for a feature called "move" even though it is technically moving the adjacent faces.
Website: ovyl.io
1. it looks like you'd essentially like to have no limit on the number of faces selected since you set it to 100. If you just delete this, it won't have a limit
2. if you prefer to have a different default value (this feature seems like it's for clearances so the default is probably too big) you can replace this
with this
Website: ovyl.io
I'm still fairly new to it as well, so I can still remember all the silly stuff I got hung up on starting out (and still do as you can see).
Website: ovyl.io
Could you give me another pointer? My code is not quite there, probably way off actually.
Here is the feature on branch B1
https://cad.onshape.com/documents/725911b3d26eaad0ab951314/w/c77dd9c784148297a7d5707a/e/6dee0c37cda944e0b01e5cb0
re: manipulator. I've never used one, but it has something to do with the Manipulator Change Functions and Editing Logic stuff at the bottom of the page. Let us know how it goes.
Website: ovyl.io
Website: ovyl.io
