How do I use the other faces found with qFaceOrEdgeBoundedFaces
Cache_River_Mill
Member Posts: 225 PRO
Hello,
I have selected my inner face, I also selected a boundary. The query found 3 faces between face 1 and the boundary. How do I know what to call the other faces that the query found so that I can use them? I believe qUnion keeps them in order, but I'm not sure how to use faces 2 & 3 that the query found.
Code:
var allLayers = qFaceOrEdgeBoundedFaces(qUnion([definition.faces1, definition.boundary]));
Code:
If you use qAdjacent with AdjacencyType.EDGE, it will only get the closest face.
