Feature UI hack help
EvanReese
Member, Mentor Posts: 2,856 PRO
What's a cleaner way to do this? The feature is here.
For the UI of the Part Name feature, I want the ability to switch segments between a string or formula, but I don't want to make the feature super long with boolean boxes. I've kind of hacked it by using the OPPOSITE_DIRECTION booleans, which gives me a much cleaner and brief layout, but it feels kinda hackey because it is.
1
annotation {"Name" : "Visible name", "UIHint" : [ "DISPLAY_SHORT", "FIRST_IN_ROW" ] } definition.isExpression is boolean; if (definition.isExpression) { annotation {"Name" : "Expression", "UIHint" : UIHint.DISPLAY_SHORT } isLength(definition.expression, LENGTH_BOUNDS); } else { annotation {"Name" : "String", "UIHint" : UIHint.DISPLAY_SHORT } definition.string is string; }Up to you if you like checkboxes better than flip buttons.
