Assembly Dimensions
in Drawings
I need some help. I am trying to assemble parts in the assembly view. I am trying to make a metal basket and I have to place supports 10 inches apart. I am trying to figure out how to tell onshape that I want to put each tube and center it on 10 inches, 16 inches, and 26 inches. OR how do I "mark" it when I am making the part? Not sure if this make sense or not.
You can also use the Linear Pattern tool in the assembly
You can also move the location of mates
Here I used the Fasten Mate function to connect the green cube to the corner of the gray cuboid
Then, I adjusted (moved) the location of the mate to be OF THE CORNER of the gray cuboid, which in turn moved the green cube
If you want to change the distance of one part to the other within the assembly,
1. you could use the in-context editing command to alter the sketch
or
2. you could select the part studio tab and edit your sketch
Doing either of the above, will change the location of the parts WITHIN THE ASSEMBLY, as the parts are mated to the sketch
