Sheet Metal Tab - Subtraction Scope & Offset
in General
Wow! Just figured out what subtraction scope and subtraction offset are for in the sheet metal tab tool. In a free moment this morning I was googling "sheet metal" "subtraction offset" and asking myself, "is that really a thing?"
Then I stumbled onto one of @cody_armstrong 's tech tips and learned that it's not a thing, except in Onshape. This is absolutely brilliant to be able to use a tab profile sketch that is NOT necessarily coplanar with the flange to be merged with. And to be able to merge that tab with one sheet metal part while subtracting it from another (subtraction scope) and specifying the kerf width (subtraction offset) in a single feature is icing on the cake.
I realize that I am only 2 years and 364 days behind the curve in singing the praise of this tool now (https://www.onshape.com/cad-blog/tech-tip-creating-sheet-metal-tabs-in-onshape ). Old dog, new trick. If you haven't played with the sheet metal tab tool yet, I strongly encourage you to do so.
My compliments to the OS crew for developing the sheet metal tab! This is a very powerful tool.
4
It also can add multiple tabs at once (from the same sketch, but on different sheet metal faces)
What do you want unfold and refold to do?
We can sketch on the flat pattern and cut the flat pattern.
The Fold SM feature (that I wrote) currently only works for bends with only one segment.
@matthew_stacy
You can make this part fully 'design intented' without variables with only 5 features instead of 7.
https://cad.onshape.com/documents/205790153bf985484ba7fc4f/w/3189789ec786e8b0eec93c6b/e/cde6358549db8712223bcf4e
In order to use the Fold tool, the part has to already be converted to sheet metal, which is where you would put the default bend radius and k factor.
Currently, Onshape does not support having a custom k factor for a bend, so I cannot do this in the feature at the moment.
Yeah — using extrude is better than tab
