3d spiral issues
Member Posts: 46 PRO
edited September 2020 in Community Support
Hi,
I have 2 questions, which are maybe related.
I'm using a 3d spiral FS
https://cad.onshape.com/documents/f437577a13ebbc350129b4a0/w/1873523e917e24872187e57a/e/3818058990e621d97e65afc3
to create a bending twisted loft.
Situation 1:
The 3d spiral is following the spline.
But the spiral points do not end up at the profile sketch, which give problems with piercing the profile sketch.
The spline needs to be 100% vertical. But how do i do that?
A solution is to use a sketch line and connect a spline. But the FS does only work with a spline.
Situation 2:
I have the problem that my helix doesn't start and end on the same axis points:
I don't know how to fix this?
I have made my situation public:
https://cad.onshape.com/documents/4e225d938e08997721242a8b/w/b84dd15a33cf99a5324034e0/e/b3d1711686f659df427c4e2b
Note1: The profile sketch is in this example not the end profile sketch.
Note2: Anyone with a better topic title?
Thank you!
