How to get all intersections with the evRaycast feature with courved edges?
timo_schmid
Member Posts: 36 EDU
in General
Hi everyone,
I'm using the ev Raycast feature to get the intersection points of a line and a courved edge. But when it hits the same edge twice (i.e. it is a courved edge) it will always only give one of the intersection points as a result. (see picture)
How is it possible to get all (usually two) intersection points?
Thanks for you help,
Timo
OptionsMBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU@timo_schmid
I currently have an open bug with that. A workaround I found was to do another ray cast directly after that point (plus 0.01 of a mm)6
