What is the easiest way to get the transformation matrix between mates? Onshape to ROS URDF
My goal is to import a model to my ROS environment (URDF file directly).
This process involves graphically defining critical frames on the assembly/part model, to feed a tree frame (ROS tf_frames). I'm using Onshape Mates to define those so called critical frames.
URDF parameters expect xyz rpy values (translation and rotation transform).
I want to get those values from those defined frames (represented by Mates) using Onshape.
Hi @leroy_eli,
Have you looked into https://github.com/Rhoban/onshape-to-robot ?
