Cannot loop through opExtrude more than 10 times
Alex_Kempen
Member Posts: 258 EDU
Hello,
I was recently working on a FeatureScript when I discovered that an opExtrude contained in a loop was failing unexpectedly. I did some investigating, and soon discovered that it was consistently failing on the 10th iteration. Here is the extrude in question:
Here's the console:
I also tried a variety of different Id methods known to work for me in the past, including id + i + "extrude" and id + ("extrude" ~ i), but to no avail.
Interestingly, the error returned by opExtrude wasn't an Id error, but rather an @opExtrude: EXTRUDE_FAILED error, with warning message "Failed to extrude selections, check input". However, selecting a piece of geometry, receiving the error, and then deselecting a different piece of geometry would cause the geometry previously selected to suddenly work, and the opExtrude consistently fails on the 10th iteration regardless of the inputs fed into it. Thus, I'm at a loss for what the problem is.
Here's a link to the document:
https://cad.onshape.com/documents/0ab5631e453e51d5638fe9ad/w/b7ca19260ef980686fa7b547/e/b8c57994eb6e2b2bbd5cba2e
The extrude that is failing is on line 498, inside the function extrudeRibs. It is tied to the array parameter located in the rib tab.
println(id + unstableIdComponent(i) + "extrude");
try
opExtrude(context, id + unstableIdComponent(i) + "extrude", {
"entities" : ribGroups[i],
"direction" : direction,
"endBound" : BoundingType.THROUGH_ALL,
"startBound" : BoundingType.THROUGH_ALL
catch
println(i);
debug(context, ribGroups[i]);
debug(context, direction);
Note that the extrude is located inside the function extrudeRibs, and the id passed into extrudeRibs is id + "rib".Here's the console:
Alex_Kempen
Okay after doing some more examination over the weekend, I discovered that looping through extrudes with BoundingType.THROUGH_ALL was resulting in errors due to the entities becoming to large. This problem also seemed to have been exacerbated by extruding THROUGH_ALL in both directions. I've made my document private again for now because it's kinda neat but also WIP, and I want to avoid sharing it to much until it's in a state where I'm happy with it. Hopefully soon!Software Developer at Epic Systems
FRC Design Mentor - Team 1306 BadgerBots0
Can you make the document you linked public?
