"SKETCH COULD NOT BE SOLVED" SKETCH ENTITIES TURNED RED
Patricia_Sugiarta
Member Posts: 2 PRO
in General
I want to extrude the box that located in the middle of the box. I'm sure that the 4 other box on each side have the same size but the extrude has one sided error. Is there any solutions to this problem?
Either create the blocks as separate solids or make sure that there isn't a boundary of 0 thickness between the two.
An intuitive way of thinking about it is if you fillet that 0 thickness edge, which of these shapes should it produce?
This situation is ambiguous, so to avoid situations like this, Parasolid prohibits non-manifold geometry.
