Getting starting in C#
alan_baljeu
Member, User Group Leader Posts: 111 ✭✭
Since I last was here, I figured out how to get the API keys. Now I have downloaded from git OnshapeWindowsSample. I set the environment variables as instructed here:
https://github.com/onshape-public/app-windows-sample
(Open question: the image says partner.dev.onshape.com, but the text says cad.onshape.com. Which is right?).
When I run the C# console app, I get in the web browser the json below. What do I need to do to get this working? URL: https://oauth.onshape.com/oauth/authorize?response_type=code&client_id=....&&grant_type=authorization_code&redirect_uri=http://localhost:9326
"moreInfoUrl" : "",
"message" : "error=\"invalid_grant\", error_description=\"Application requested an invalid redirect URL http://localhost:9326\"",
"status" : 400,
"code" : 0
Creating knowledge-driven design automation software, for molds, etc.
www.virtualmold.com
www.virtualmold.com
The requested URL was not found on this server. If you entered the URL manually please check your spelling and try again.
If you think this is a server error, please contact the webmaster.
Error 404
localhost
Apache/2.4.37 (Win32) OpenSSL/1.1.1 PHP/7.2.12
</code>So then I created a folder in my htdocs, called onshape-test, and I get:</pre></span><br><h1>Index of /onshape-test</h1><table><tbody><tr><th><img alt="ICO" src="http://localhost/icons/blank.gif"></th><th><a rel="nofollow" href="http://localhost/onshape-test/?C=N;O=D">Name</a></th><th><a rel="nofollow" href="http://localhost/onshape-test/?C=M;O=A" title="Link: http://localhost/onshape-test/?C=M;O=A">Last modified</a></th><th><a rel="nofollow" href="http://localhost/onshape-test/?C=S;O=A">Size</a></th><th><a rel="nofollow" href="http://localhost/onshape-test/?C=D;O=A">Description</a></th></tr><tr><th colspan="5"><hr></th></tr><tr><td><img alt="PARENTDIR" src="http://localhost/icons/back.gif"></td><td><a rel="nofollow" href="http://localhost/">Parent Directory</a></td><td> </td><td class="post-text-align-right">-</td><td> </td></tr><tr><th colspan="5"><hr></th></tr></tbody></table><div>Apache/2.4.37 (Win32) OpenSSL/1.1.1 PHP/7.2.12 Server at localhost Port 80<br><br></div><pre class="CodeBlock"><code><div>Is there more to this test app or where do I go from here?</div><p></p>www.virtualmold.com
<div>Opening browser window for Onshape authentication... </div><div>Error: StatusCode: 401, ReasonPhrase: 'Unauthorized', Version: 1.1, Content: System.Net.Http.StreamContent, Headers: </div><div>{ </div><div> Connection: keep-alive</div><div> Strict-Transport-Security: max-age=31536000; includeSubDomains</div><div> X-Content-Type-Options: nosniff</div><div> X-XSS-Protection: 1; mode=block</div><div> Cache-Control: no-store, must-revalidate, no-cache</div><div> Date: Sat, 31 Oct 2020 13:48:10 GMT</div><div> Server: nginx</div><div> Content-Length: 55</div><div> Content-Type: application/json; charset=utf-8</div><div> }</div><div> Press any key to continue . . .</div><div></div>but, onshape-test is a folder, not a program. What am I missing?
www.virtualmold.com
