Why if I wrap a sketch on a cylinder it doesn't behave like a Helix?
Sketch wrapped on cylinder with curve pattern i have problems
I need to have multiple helices on a cylinder on which to add Curve pattern components.
but if I create a helix with its function, the curve pattern alignment is correct
while if it creates a helix obtained from a "wrap" the alignment is not right, there is no concentricity.(clearly Keep orientation is disabled)
Thank you so much
https://cad.onshape.com/documents/8093713ecba17430a2eef231/w/1328a799055f79056bd7a52f/e/66d906cc7c2a70bbecf4123a
Thank you so much
https://cad.onshape.com/documents/fcad26be1889afb70377be4d/w/2721e8a25185e00ebbdcf774/e/95db55416d290046f513e4c9
