Geometric Dimensioning and Tolerancing Y14.5-2009
in Drawings
I would like to know when we, the users of OnShape that make drawing representable of the Y14.5-2009 standard, will have a full compliment of symbols required to adhere to the standard?
I have yet to be able to produce a viable document that meets my clients requirements and has now begun to affect my business.
2
And still waiting for Datum Targets and Continuous Feature Symbol.
My bad I forgot they updated the spotface symbol.
A workaround I found was to go to https://www.tec-ease.com/gdt-terms.php
and grab the symbols I want an import them into a drawing, you can then manipulate the size and placement.
This is a workaround for the time being, but it will get you where you need to go as far as symbols go.
Still trying to figure out a workaround for Datum targets.
I will give you a shout if one avails itself
Interesting approach. Not sure how to import into a drawing but will give it a try.
Thanks,
Managed to do what I think you described. Only problem is it doesn't attach to anything.
Any update on this? I'm dimensioning a casting and need datum-targets but still looks like these are not part of Onshape.
Thanks
