How do i use chamfer on half the edge of a cylinder? Not the whole but just a certain part
Problem with chamfer
  • steve_shubinsteve_shubin Member Posts: 1,118 ✭✭✭✭
    @oscar_rehnström
    There are a number of ways you could do it
    Here’s one way
    Make a sketch of a triangle
    Then use revolve set to subtract
    Select the sketch of the triangle to subtract from the cylinder
    For the axis of this second revolve, select the vertical surface of the cylinder
    edited November 2020
