Variable thickness on a revolve / loft for a toroidal knot
sanford_morton
Member Posts: 6 EDU
Hi OnShape team & users, I could use your help determining how to introduce variable thickness to a revolve / loft in this document.
The inside of the toroid (donut hole if you will) should be thinner than the outside. Said another way the lattice should be more delicate on the inside and thicker towards the outside.
I'm open to any method to achieve this. My intuition would be to define the profile's width as a function of radius from the origin of the top plane - but I'm not sure how to begin setting this up.
Thanks!
Sam
Thanks!
Sam
Yes your radial example is exactly what I was looking for. Do you mind helping me conceptually / tactically understand how the "d(r) graph" sketch you drew is used by the variable section feature? (image below) Trying to understand how I would recreate this effect myself.
Thanks so much!
