Circular pattern on text
johannes_beckerjohannes_becker Member Posts: 8 ✭✭
Hello,
Is there a way to use the circular pattern tool on a text element in a sketch? I like to place several text elements on a circle radially facing to the center of the circle (like the numbers on a watch face). My idea was to create one text element at the 12 o'clock position and them use the circular pattern tool to copy them around the circle.
However I can't select a text element when in the circular pattern tool. Do I really have to create and then move in place each individual text element?
Johannes
