Trying to make the slot larger
mario_darceuilmario_darceuil Member Posts: 113 ✭✭
The slot will not be dimensioned. I've tried. I need a bigger radius and a larger slot and it's not working. I am just getting red errors. I click on slot and double clicked on the dimension tool.
  • MichaelPascoeMichaelPascoe Member Posts: 2,814 PRO
    Can you share the document so that we can take a look at what is wrong?
    RENDERCAD
  • mario_darceuilmario_darceuil Member Posts: 113 ✭✭
    1) created a line 2) clicked on slot and the slot appeared 3) I double clicked the dimension tool and the slot disappeared.
    Once you click the line to create the slot, you have to press enter to confirm the diameter of the slot.
    If you skip that step, the slot will disappear.
    RENDERCAD
