How do I force a radius leader to extend from the center?
T_RathierT_Rathier Member Posts: 47 EDU
I am trying to add an orthographic dimension for the radius as indicated on the attached drawing. How do you force the leader to the inside when the text is on the outside?
  • T_RathierT_Rathier Member Posts: 47 EDU
    This is a double post, I didn't think it went through.
