Hole diameter precision in drawing hole table
philmat15philmat15 OS Professional Posts: 12 PRO
The hole table properties allows setting the hole location precision to 3 digits, but there's no option to set the hole diameter precision.  I can make the hole diameter precision 3 digits in the table by setting the drawing default to that.  I would prefer to use a drawing default of two digits, otherwise I have to individually edit any dimension elsewhere in the drawing that I want to be two digits down from three.
  • T_RathierT_Rathier Member Posts: 47 EDU
    I asked a very similar question about hole notes. It has been put in as a request to Onshape.
