Copy A Sketch - Onshape Update 29JUN15
christopher_owens
Member Posts: 235 ✭✭
Great update! First I tired "Fix" all entities in existing sketch... pasted sketch has all entities "Fix"ed. Eliminating need to redimension new sketch.
3dcad
Member, OS Professional, Mentor Posts: 2,482 PRO
You can create new part from that sketch and scale that part using Transform -> Scale uniformly, then boolean to combine again.
//rami5
Yeeeah! By deleting the Horizontal constraint and adding a Vertical to THE line in the outer rectangle the section rotated as I wanted! Whew!
