Intersect Views (New Custom Feature!)
MichaelPascoe
Member Posts: 2,822 PRO
Intersect Views
https://cad.onshape.com/documents/1755463e12cab51e4a5de51f/w/07865f22b67cc44e473c99a3/e/302fb7288b77057ca30414fb
How to add a custom feature to your tool bar:
RENDERCAD
11
RENDERCAD
This is definitely one of my favorites so far.
RENDERCAD
Hope this translator works
RENDERCAD
Twitter: @BryanLAGdesign
I have added a "Show behind the scenes" configuration checkbox for the example tab. This should help explain how it works.
RENDERCAD
Feature Tip!
Here is a new trick I learned today. If your part is identical from the front view and the side view, you can use one sketch for both viewsRENDERCAD
Intersect views has been moved to this location: Intersect views
Update!
This feature has been completely re-written for the Onshape live 2022 contest. Hope you enjoy the update!RENDERCAD
This update is provided by @emagdalenaC2i, thanks C2i for the update!
Update!
- Keep Front reference origin.
- Hide reference lines.
- Sub feature Revolve.
- Sub feature boolean option "New".
https://cad.onshape.com/documents/6c4ae7073bbb41d485299a31/w/a75a42c352a4a591769b844c/e/3fa7aee126526b3c0974a8d5?renderMode=0&uiState=61f8c847698d9a75bc84c786RENDERCAD
