How do I set the "MaxNumberOfPicks" with a query?
MichaelPascoe
Member Posts: 2,745 PRO
How do i set the max number of picks with a query?
precondition
annotation { "Name" : "Group Size" }
isInteger(definition.quantity, POSITIVE_COUNT_BOUNDS);
annotation { "Name" : "Parts", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1 }
definition.parts is Query;
}<br> Learn more about the Gospel of Christ ( Here )
Long answer: You could use the editing logic function to force a variable max number of picks. You'll need to decide what happens to the query when you go over the max number of picks; do you delete the last item from the query, or get rid of the first?
Example:
annotation { "Feature Type Name" : "My Feature", "Editing Logic Function" : "EditingLogicFunction" } export const myFeature = defineFeature(function(context is Context, id is Id, definition is map) precondition { // Define the parameters of the feature type annotation { "Name" : "My Query", "Filter" : EntityType.FACE } definition.myQuery is Query; annotation { "Name" : "Max size" } isInteger(definition.querySize, POSITIVE_COUNT_BOUNDS); } { // Define the function's action }); export function EditingLogicFunction(context is Context, id is Id, oldDefinition is map, definition is map, isCreating is boolean) { if (size(evaluateQuery(context, definition.myQuery)) > definition.querySize) { definition.myQuery = oldDefinition.myQuery; } return definition; }The reason I need to set the "MaxNumberOfPicks", is so that once you fill the query, it will automatically tab you to the next input box.
Thank you Mahir, I will give this a try.
Would this have any relation to a selection-driven array parameter?
That could be a decent work around. So I can have a drop down menu with 5 or so different group sizes. Depending on which group size you choose, an almost identical query will be chosen that is set up with a different "MaxNumberOfPicks".
Thanks for the help!
Here is the feature I used this info to make:
https://forum.onshape.com/discussion/15155/boolean-groups-new-custom-feature#latest
It doesn't auto tab to the next box, but it turned out nice.
