How do I set the "MaxNumberOfPicks" with a query?
MichaelPascoe
Member Posts: 1,724 PRO
How do i set the max number of picks with a query?
precondition { annotation { "Name" : "Group Size" } isInteger(definition.quantity, POSITIVE_COUNT_BOUNDS); annotation { "Name" : "Parts", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1 } definition.parts is Query; }<br>
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
Long answer: You could use the editing logic function to force a variable max number of picks. You'll need to decide what happens to the query when you go over the max number of picks; do you delete the last item from the query, or get rid of the first?
Example:
The reason I need to set the "MaxNumberOfPicks", is so that once you fill the query, it will automatically tab you to the next input box.
Thank you Mahir, I will give this a try.
Would this have any relation to a selection-driven array parameter?
That could be a decent work around. So I can have a drop down menu with 5 or so different group sizes. Depending on which group size you choose, an almost identical query will be chosen that is set up with a different "MaxNumberOfPicks".
Thanks for the help!
Here is the feature I used this info to make:
https://forum.onshape.com/discussion/15155/boolean-groups-new-custom-feature#latest
It doesn't auto tab to the next box, but it turned out nice.
