Making a (not so) simple tapered side planter box
patrick_shea
Member Posts: 63 EDU
in General
It is a simple design - 15 degree slope, side are approximately 16 " long, and 5" high. The problem is the corners are all compound angles, and I can't figure out how to draw them. Building it will be easier than drawing it. Can someone guide me how to draw it properly - see attached image.
Pat
Pat
Make all parts in a single part studio; no assembly needed. Two sketches symmetrical about origin; extrude two sides between vertices; extrude other two sides between inner faces; extrude between outer faces to remove excess: https://cad.onshape.com/documents/a413994eb043be22cfa7a54e/w/b2cf6d4b201a5e24499b0503/e/1b997ec6b2dab8b26692e180
https://cad.onshape.com/documents/9ab9639be5e96dcf794e8877/w/2643288d35dcc90ae2195cc9/e/9d831eaf0f77c7d148664ddd
