How to put a image into a 3D object or solid?
marcos_pinto124
Member Posts: 11 ✭
I finished my construction and used the insert image toll to insert a image into my solid, but it disappeared when I left the sketch, do I have to retrace it or there is another way to insert a image into a solid, and make it stay there, even after leaving the sketch.
Jake_Rosenfeld
@marcos_pinto124
Likely your sketch is just hidden. If you insert an image into your sketch, it should stay visible as long as the sketch is visible. Try clicking on the eye icon next to the sketch in the feature list.
Please also feel free to vote on this improvement request: https://forum.onshape.com/discussion/2718/decals-or-images-as-skins-on-solid-faces-or-surfaces which represents a more robust improvement to adding images to partsJake Rosenfeld - Modeling Team1
