Do you really want to Delete this Parts Studio Tab? Hope your sure!
christopher_owens
Member Posts: 235 ✭✭
Hello! I notice when deleting a Parts Studio Tab you don't get a "Are you sure?" question! Be careful picking "Export..."!
I agree with you. I know people (boring people) that operate their GUI's like my mom, full of caution and care. I have years of street fighter button mashing twitch reflexes and an MTV attention span. Every potentially undesirable action must be reversible, preferably easily reversible.
In this case it is...
The workspace history (clock icon at top) will allow you to restore the workspace prior to the deletion, assuming you noticed that you deleted.
5 -
@christopher_owens I have a hunch that things can be simpler than what you are experiencing.
The fundamental design of Onshape is such that we should not have to do anything special to avoid losing things.
Are you familiar with version saving and branching?
5 -
Sorry, I never clarified the actual juggling process...
- Import an external part into a part studio
- Delete part studio and import tab
- Create new blank part studio
- Sketch and extrude something.
- ! Realize we needed those tabs after all !
- History->[line of last tab deletion]->options->restore
- Version->save version "merge_anchor"
- History->[line of final extrude creation]->options->restore
- Version->"merge_anchor"->options->branch to create workspace "repaired"
- History->[line of part import]->options->restore
- version->"main"->options->merge into current
- ! fixed !
It's not easy. It took me 3 tries to recall how to do it and document it above. My first attempt failed and my second attempt had a bunch of extra, unnecessary save points and branches.
5 -
My test situation was:
1. Create models in multiple tabs
2. "Accidentally" delete one tab
3. Continue working on another tab (create more features on top of existing)
4. Realize that you have lost a tab by mistake
I wasn't able to restore tab and the work done after accident using versions and history.
I tried also to copy lost tab to clipboard, restore at point where newly added work is there, paste --> Error: Failed to paste element. An internal error has occurred.
But as a workaround I did manage to finish this test by:
5. Create version with new work in.
6. Go back in history where lost tabs are still there
7. Copy these tabs to clipboard and paste into new temp document
8. Restore version with new work
9. Copy-Paste lost tabs from temp document to original
No features or tabs lost, don't know what happens to assemblies if they had parts from tabs that were accidentally deleted and restored by this workaround.
I would still prefer un-delete function for tabs with maintaining possible assemblies with parts from deleted tabs.
//rami5
5 -
@traveler_hauptman : OK... since this was a Part Studio session I was trying things out in, I restored back to that Delete Tab instant. Now I noitice everything else I did after that is "suspended in time". When I go 'forward' to restore what I did after the delete... the tab is still deleted. Hmmm...0
There may be a little version control magic one can play. I have not tested it but in theory....
Roll forward so your new changes are captured but the tab is deleted. Save a version and branch it. Roll back to where the deleted tab is restored. Save that version. merge the branched (new changes) version on to the version with the restored tab....
It depends on how Onshape implemented their merge...
Well, the Tab I test deleted contained a file.x_t file. So I can go back, restoring the tab, download the file, go forward restoring what else I did, and then import the x_t file again. I will try deleting a Parts Studio, making some other changes, then go back and copy the Parts Studio to the clip board, go forward, and paste in the Parts Studio. Hmmm... now what happens if you delete a Parts Studio where parts are use in an Assembly! YIKES!0
@christopher_owens That's surely a problem. I'll see if we can get a confirm dialog in there. In the mean time, @traveler_hauptman's solution of restoring from the workspace history should get your part studio back.0
Of course when I reimported the x_t file I get an assembly(1) tab and a assembly(1)parts tab... SOoo...that would safe guard against "losing everything" if once and a while you saved an 30JUN15_0327PM.x_t file!0
5 -
Well that did give me the opportunity to "OS!!" delete the assembly(1)parts tab. Yep assembly(1) is empty with a lot of red text in the Instances list!0
AH! I can easily restore that and the assembly has all it's parts back. So if you Delete and tab "OS!!" best to restore it right away!!0
@traveler_hauptman Not familiar with the version saving and branching yet! I have a feeling I am going to do some reading on those! Thanks! As I said I was just experimenting with things!0
Take a quick look when you can. It replaces saving backup copies and creating copies for testing.
'Save version' (in the versions flyout) is like saving a backup copy of your work that you can easily return to at any time.
'Branch to create workspace' (in the gear menu of each saved version) is a little like creating a copy for testing so that you can simultaneously try different approaches.
That's an oversimplified explanation but good enough to start using it.
For the record, I tested that version juggling theory I suggested and it works (blending changes made after deleting a workspace with the undeleted workspace.)
@traveler_hauptman That is really clever! I think it's actually a general way of "undoing" any contiguous sequence of steps in the middle of the document history.
A problem with copying the part studio tab from an earlier version, besides not restoring assembly references, is that that creates a new tab (different than the old part studio) so merging changes to that part studio from other branches won't work.
Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0 -
I didn't succeed on my test. I deleted a tab and then created sketch and feature to another tab. I was only able to bring back the lost tab but was not able to merge work done after that.. I did a lot of restoring and testing in between so that might cause it not to work. But I did manage to create a version with new work and another version with lost tab restored; but merge only worked in one direction.traveler_hauptman said:For the record, I tested that version juggling theory I suggested and it works (blending changes made after deleting a workspace with the undeleted workspace.)
//rami0 -
- ! fixed !
5 -
//rami5
