evBox Help?
MichaelPascoeMichaelPascoe Member Posts: 2,785 PRO
edited January 2021 in FeatureScript
I have a loop for each selected part. The bounding box works fine when the selected parts are not near each other, but when the parts are touching, the evBox does not work even though it's only evaluating one part at a time. Each time the feature loops, there is only one part in the loop at a time. There is nothing to intersect.
Here is the code:
 https://cad.onshape.com/documents/55a675ab42d69e59cec13422/w/6c9a7e0449c7b3d48e26243b/e/fc4f13dd438b78b27b74efb0
What am I missing here?
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    I see that you've got the entire set of parts as the target for the opSplitPart.  That may be causing parts to split before you have a chance to iterate over them.  Try splitting just the current part (my guess is that's what's intended).  Unrelated to this problem, I also suggest using forEachEntity for downstream reference stability.
  • MichaelPascoeMichaelPascoe Member Posts: 2,785 PRO
    edited January 2021
    Thank you for the tips @ilya_baran
    And thank you as well @Jason_S
