I'm not sure why OS isn't letting me to make an assembly with a part so I can export it as an STL?
caroline_read
Member Posts: 31 ✭
It says that the thing I made is a surface but not a part and ultimately all I want to do is download it as an stl and then 3d print it just for practice. Not sure where I'm getting lost.
UPDATE: FIGURED IT OUT not sure how to delete this post though...
christopher_owens
Member Posts: 235 ✭✭
@caroline_read : If you have more that one Part in your Part Studio you can 'right-click' on it in the Parts List then select "Export to STL..." to only export the selected part.1 -
traveler_hauptman
Member, OS Professional, Mentor, Developers Posts: 419 PRO
@caroline_read There will be others with the same ideas and questions. We all go through a learning phase and come from diverse backgrounds.
Can I suggest you edit your post title so it shows up in searches?
"I'm not sure why OS isn't allowing me to make an assembly with a part I just made so I can export it to STL"
5
