Linear Patter/ Linear Sketch Patter Instance Skip
josh_harrisonjosh_harrison Member Posts: 2 PRO
Is there a way to skip insances using the Linear Patter either as a part or in a sketch?
    Not directly. But you can delete unwanted parts or faces after the fact to have a similar effect.
  • josh_harrisonjosh_harrison Member Posts: 2 PRO
    This is a great work around. For a sketch you could sellect what instance you want to use to creat the feature when doing an Extrude.
