Is there a way to define and extrude a conical hole through a part?
paul_elliott363
Member Posts: 7 ✭
I have a part that mounts onto a conical airway but can't workout a way to do this beyond creating it as a part and using it as a boolean remove? Any faster ways?
mahir
Member, Developers Posts: 1,320 ✭✭✭✭✭
@paul_elliott363,
It seems like you're just starting out with CAD. Instead of telling you how to do very specific tasks only for you to run into another roadblock immediately afterward, I believe it would be much more useful for you to go through the tutorials. They do a good job of showing you the basics and beyond. Check the link below.
Onshape CAD Fundamentals1
