change composite part color with FS?
EvanReese
Member, Mentor Posts: 2,856 PRO
I've tried setProperty() with the composite and it says only bodies and faces are allowed. I've tried qContainedInCompositeParts() to get the bodies inside of it, and it still doesn't do much. How do I change the color of a closed composite part?
_anton
Member, Onshape Employees Posts: 523
Because of the way it's implemented, the composite body contains a vertex. I'd get just the composite body like so:colorBodies = qCreatedBy(id + "compositePart1", EntityType.BODY);
I was able to get it working like this, but where did the vertex come from? The only inputs to the composite part were 4 solid bodies.
