How can I efficiently find every body that has a coplanar face to an input?
EvanReese
Member, Mentor Posts: 2,856 PRO
I have a query of planar face(s) as inputs, and would like to query every body that has any face that is co-planar with any of the inputs (selectedFaces). I got it working like this, but I'm getting really bad re-build times. I'm sure there's got to be a much faster way that my 5pm brain isn't seeing. Anybody have any tips or examples for me?
var selections = qNothing();
var allPlanarFaces = evaluateQuery(context, qSketchFilter(qConstructionFilter(qGeometry(qEverything(EntityType.FACE), GeometryType.PLANE), ConstructionObject.NO), SketchObject.NO));
var selectedFaces = evaluateQuery(context, definition.faces);
var selectedBodies = qNothing();
for (var face in selectedFaces)
var plane = evPlane(context, {
"face" : face
for (var referenceFace in allPlanarFaces)
var referencePlane = evPlane(context, {
"face" : referenceFace
var isCoplanar = coplanarPlanes(plane, referencePlane);
if (isCoplanar)
selections = qUnion([selections, qOwnerBody(referenceFace)]);
}0
Jake_Rosenfeld
Hey Evan!
I suspect the fastest you can do it is something like:// -> notation is newly released. // qGeometry(qEverything(EntityType.FACE), GeometryType.PLANE) can now be written more simply as as qEverything(EntityType.FACE)->qGeometry(GeometryType.PLANE) // The arrow simply means "insert the thing before the arrow as the first argument to the thing after the arrow" const allPlanarFaces = qEverything(EntityType.FACE)->qGeometry(GeometryType.PLANE)->qConstructionFilter(ConstructionObject.NO)->qSketchFilter(SketchObject.NO); const resultArr = []; for (var face in evaluateQuery(context, definition.faces)) { const plane = evPlane(... face ...); // filter down to parallel planes, and then filter further to coincident, resulting in coplanar const coplanar = qParallelPlanes(allPlanarFaces, plane.normal)->qCoincidesWithPlane(plane)); resultArr = append(result, coplanar); // Appending to an array is better than qUnion with a master query<br>} const result = qUnion(resultArr); debug(context, result);
** formatting is getting messed up. -> should be "->"Jake Rosenfeld - Modeling Team0 -
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,255
Haven't tested it, but qCoincidesWithPlane would be key here I think. Something like:
qEverything(EntityType.FACE)->qCoincidesWithPlane(myPlane)->qOwnerBody()
looking at our internal implementations, it's possible that qEverything(EntityType.FACE)->qParallelPlanes(myPlane)->qCoincidesWithPlane(myPlane)->qOwnerBody() would actually be faster -- worth testing.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
// -> notation is newly released. // qGeometry(qEverything(EntityType.FACE), GeometryType.PLANE) can now be written more simply as as qEverything(EntityType.FACE)->qGeometry(GeometryType.PLANE) // The arrow simply means "insert the thing before the arrow as the first argument to the thing after the arrow" const allPlanarFaces = qEverything(EntityType.FACE)->qGeometry(GeometryType.PLANE)->qConstructionFilter(ConstructionObject.NO)->qSketchFilter(SketchObject.NO); const resultArr = []; for (var face in evaluateQuery(context, definition.faces)) { const plane = evPlane(... face ...); // filter down to parallel planes, and then filter further to coincident, resulting in coplanar const coplanar = qParallelPlanes(allPlanarFaces, plane.normal)->qCoincidesWithPlane(plane)); resultArr = append(result, coplanar); // Appending to an array is better than qUnion with a master query<br>} const result = qUnion(resultArr); debug(context, result);** formatting is getting messed up. -> should be "->"
I might be taking this script in a whole different direction, but If I come back to this, I'll implement these changes. I'll mark it "answered" even though I've not tested it, because I'm pretty sure you're going to be right.
