How can I efficiently find every body that has a coplanar face to an input?
EvanReeseEvanReese Member, Mentor Posts: 2,856 PRO
I have a query of planar face(s) as inputs, and would like to query every body that has any face that is co-planar with any of the inputs (selectedFaces). I got it working like this, but I'm getting really bad re-build times. I'm sure there's got to be a much faster way that my 5pm brain isn't seeing. Anybody have any tips or examples for me?
var selections = qNothing();
var allPlanarFaces = evaluateQuery(context, qSketchFilter(qConstructionFilter(qGeometry(qEverything(EntityType.FACE), GeometryType.PLANE), ConstructionObject.NO), SketchObject.NO));
            var selectedFaces = evaluateQuery(context, definition.faces);
            var selectedBodies = qNothing();
            for (var face in selectedFaces)
                var plane = evPlane(context, {
                        "face" : face
                for (var referenceFace in allPlanarFaces)
                    var referencePlane = evPlane(context, {
                            "face" : referenceFace
                    var isCoplanar = coplanarPlanes(plane, referencePlane);
                    if (isCoplanar)
                        selections = qUnion([selections, qOwnerBody(referenceFace)]);
    edited January 2021 Answer ✓
    Hey Evan!
    I suspect the fastest you can do it is something like:
    // -> notation is newly released.
    // qGeometry(qEverything(EntityType.FACE), GeometryType.PLANE) can now be written more simply as as qEverything(EntityType.FACE)->qGeometry(GeometryType.PLANE)
    // The arrow simply means "insert the thing before the arrow as the first argument to the thing after the arrow"
    const allPlanarFaces = qEverything(EntityType.FACE)->qGeometry(GeometryType.PLANE)->qConstructionFilter(ConstructionObject.NO)->qSketchFilter(SketchObject.NO);
    const resultArr = [];
    for (var face in evaluateQuery(context, definition.faces))
        const plane = evPlane(... face ...);
        // filter down to parallel planes, and then filter further to coincident, resulting in coplanar
        const coplanar = qParallelPlanes(allPlanarFaces, plane.normal)->qCoincidesWithPlane(plane));
        resultArr = append(result, coplanar); // Appending to an array is better than qUnion with a master query<br>}
    const result = qUnion(resultArr);
    debug(context, result);
    ** formatting is getting messed up. -&gt; should be "->"
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    Haven't tested it, but qCoincidesWithPlane would be key here I think.  Something like:
    qEverything(EntityType.FACE)->qCoincidesWithPlane(myPlane)->qOwnerBody()
    looking at our internal implementations, it's possible that qEverything(EntityType.FACE)->qParallelPlanes(myPlane)->qCoincidesWithPlane(myPlane)->qOwnerBody() would actually be faster -- worth testing.
    Hey Evan!
  • EvanReeseEvanReese Member, Mentor Posts: 2,856 PRO
    Thanks so much for the willingness to educate, guys. It's so helpful to see how the pros think about breaking down a problem in steps. I also need to get with it with the -> syntax. it's so much better!
    I might be taking this script in a whole different direction, but If I come back to this, I'll implement these changes. I'll mark it "answered" even though I've not tested it, because I'm pretty sure you're going to be right.
