Hole callout in drawings according to DIN ISO 6410
maik_schoenfeld984maik_schoenfeld984 Member Posts: 3 EDU
I would like to see an option in the 'hole callout' function to switch from the current appearance:
to an  appearance according to DIN ISO 6410:
This figures are examples. This option should cover also through-holes and outer threads as well. That would be great.
Greetings,
Maik
  • mfalkensteinermfalkensteiner Member, Onshape Employees, csevp Posts: 86
    Hi Maik! Please create Improvement Requests or vote for requests in the category on the right. Thanks!
    Principal Technical Services Engineer, EMEAI
  • maik_schoenfeld984maik_schoenfeld984 Member Posts: 3 EDU
    Hi mfalkensteiner, thanks for the advice. I thought, I have done already an Improvement Requests. But maybe I have clicked something wrong. I will retry it.
    Thanks. :)
