Curved text
veronika_kadlecovaveronika_kadlecova Member Posts: 2 EDU
Hi,
I have found grat script for making curved text pp-surfacetext. It works great if I use raised add extrude type, but if I use "cut out" it gives me a mistake . Does anyone know what I do wrong? I've tried everything and I'm just starting work with onshape and similar apps so I am a bit confused.
Thank you.
  • MichaelPascoeMichaelPascoe Member Posts: 2,803 PRO
    It looks like you selected the sketch face for your "Base Surface"; try hiding the sketch and selecting the surface of the part for the base surface.
    RENDERCAD
