Apply an Extrusion to a curved surface
Can you project a sketch to a curved surface to extrude it, I would like to create a feature on a piece of tubing that is a logo cut around the tube. the way I would have done this in other software would be by projecting the sketch around that surface is there an On Shape equivalent
This is the surface I would like to apply the sketch to for context
It looks like you’ve got draft or a taper on the cylinder, so you could use Sketch Wrapper
https://cad.onshape.com/documents/6dbbbfa9dfadb45391d8b619/w/14946913a3d2d23574773eff/e/1891988d0338509da4be61f7
