Placing mate connector on origin or on planes?
nick_papageorge_dayjob
Member, csevp Posts: 1,057 PRO
Hi all, I'm getting used to mate connectors coming from ProE/Creo, if a Mate connector is where I want it. What I'm having a really hard time with is creating a mate connector either on the origin, or on the intersection of planes of my choosing. I can put a mate connector very easily on a tiny hole that is likely to move or go away, but I can't figure out how to put it on the most fundamental feature in CAD. I did a search on the forums for "mate connector on origin" and "mate connector on plane" and didn't find anything relevant. Same for the on-boarding tutorials I did. Is there a technique I'm missing to place the mate connector on origin/plane? Thank you.
2
Many features allow the use of "implicit" mate connectors, which allows you to create a mate connector within a feature. An example of this is using clicking the mate connector icon next to the plane input box when starting a new sketch. Mate Connector (onshape.com) These are really helpful and flexible.
Also, there are some times when I need an axis or "direction" for a feature input. Sometimes, I'll do like you did and just create a sketch with a construction line to use as an axis later on. However, I recently realized that when a feature needs a "direction", you can select a plane and the plane's normal direction will be used.
I've opened assemblies made by coworkers in Onshape and found no mates whatsoever. All the parts are just sitting in an unconstrained "pile" so it seems that mates are simply not really a consideration in Onshape in the same way that it is in an Autodesk product.
In addition to all the points raised by @nick_papageorge073, it seems seriously risky to me to have an assembly just floating in space.
Sorry, I was in the wrong thread!
