Why do attributes not come through when instantiating?
When instantiating part studio reference parameters, I'm able to get the attributes to come through if I use the legacy setAttribute(), but with the new setAttribute(), where you can specify a name, it doesn't seem to work?
Thanks in advance!
Thanks in advance!
This issue with named attributes is fixed in the latest standard library version. In the Feature Studio using std's instantiator, you can increase the FeatureScript version and std import version to the latest (1447) to get the fixed behavior with named attributes coming through:
Thanks for the response. Unfortunately, I've been working on version 1447... ?
https://cad.onshape.com/documents/6bf7d2234651c58fd03819fd/w/94b564b1cc6a93b376e5e72a/e/ddf3cc2d2a6eba01f8191ea0
I can't seem to access the link you sent:
"Failed to load document for workspace. Resource does not exist, or you do not have permission to access it."
